#55283 - 05/01/2002 10:02 Upgrader Stalls On "Programming flash (kernel)"
jloew
Loc: SF Bay Area
I was only able to complete upgrades using another machine. The one that fails is a Dell Lattitude cPX, and the one that succeeds is an IBM Thinkpad (both are laptops). Both have exactly the same com1 driver version and settings. Both are running Win2k Pro.
On the Dell, I have Xircom Cardbus Ethernet/Modem PCMCIA, but I think problem occurs regardless of if it's installed.
Minimal other apps running, nothing that takes COM1 that I can tell.
Anyway, not too worried since I can find a way to upgrade, but just in case someone else needs some data to work from.
-Joe
MkIIa [blue]BLUE[/blue]
#55284 - 05/01/2002 11:14 Re: Upgrader Stalls On "Programming flash (kernel)" [Re: jloew]
Sounds like a problem with the Dell's COM port. It may be sharing an IRQ with another device.
See if you can get some other thing working on the Dell's COM port such as hyperterminal.
#55285 - 05/01/2002 11:22 Re: Upgrader Stalls On "Programming flash (kernel)" [Re: tfabris]
jloew
Loc: SF Bay Area
Yeah, maybe, but I don't see any conflicts in the device manager. Is there an easy way to list all devices on an IRQ? I know COM3 would normally share IRQ4, but don't have that setup.
Keep in mind that the upgrader successfully completes many steps before stalling on this one, so I suspect there is more to it than IRQ conflict (otherwise, wouldn't everything fail?)
Didn't try hyperterminal, got a more severe problem at the moment - the display doesn't not come up at all - totally blank. I have a note to carsupport, but suspect it's a defective unit. :-(
#55286 - 05/01/2002 12:36 Re: Upgrader Stalls On "Programming flash (kernel)" [Re: jloew]
Yes. It's kind of a hidden feature in the Device Manager. It's sort of stupid the way they make you do this, I wish it were more obvious. When someone pointed it out to me (on this very BBS if I recall correctly), I was pretty upset about it:
At the very top of the device manager tree, is the computer itself. On my system, it's called "Computer". Double-click on that. This gives you an ordered IRQ list.
See what I mean? Pisses you off when you see it. Totally non-intuitive way of getting that information.
This is probably a side-effect of the failed kernel flash. Re-flash it on the working laptop.
#55287 - 05/01/2002 13:26 Re: Upgrader Stalls On "Programming flash (kernel)" [Re: tfabris]
djc
Loc: chicago
hmm. doesn't work on my installation of w2k pro, it just collapses or expands the categories under "Computer" (which on mine reads "EQUINOX", the machine's network name).
the system information tool, under the accessories -> system tools menu, has a very intuitive interface for viewing hardware configuration info.
--d.
#55288 - 05/01/2002 13:52 Re: Upgrader Stalls On "Programming flash (kernel)" [Re: djc]
Oh, I was on 98.
Try getting the "properties" for "computer". Does that work on 2K?
#55289 - 05/01/2002 14:16 Re: Upgrader Stalls On "Programming flash (kernel)" [Re: tfabris]
charcoalgray99
Well on XP it's like this:
Open Device Manager
View -> Resources by type
Expand the tree for IRQ
Tom
#55290 - 06/01/2002 10:14 Re: Upgrader Stalls On "Programming flash (kernel)" [Re: djc]
jloew
Loc: SF Bay Area
On Win2k, I found a way in the Device Manager too: Click on the menu item View, then Resources by type. However, I only show COM1 using IRQ4. :-(
Thanks for the tip on System Info, though! Even better interface.
#55291 - 06/01/2002 10:18 Re: Upgrader Stalls On "Programming flash (kernel)" [Re: tfabris]
jloew
Loc: SF Bay Area
Unfortunately, didn't help. I've been able to upgrade and download a few hundred songs via ethernet, but still not a pixel turns on. Way bummer. Now I have to wait for help. You have any idea how hard it is to wait after waiting so long??? ;-)
Was thinking of trying Display Server just so I can keep toying around, but there's a step that requires interacting with the empeg unit, and I don't know how to fly blind yet!
Sigh.
-Joe
#55292 - 06/01/2002 14:03 Re: Upgrader Stalls On "Programming flash (kernel)" [Re: jloew]
bonzi
JEmplode has 'show empeg screen' function; you have to keep pressing 'Refresh' button, though.
#55293 - 06/01/2002 19:45 Re: Upgrader Stalls On "Programming flash (kernel)" [Re: bonzi]
jloew
Loc: SF Bay Area
Cool, I'll check it out. Installing DS on beta 7 appears pretty involved anyway (reading the latest display server thread).
#55294 - 06/01/2002 21:53 Re: Upgrader Stalls On "Programming flash (kernel)" [Re: jloew]
mschrag
Loc: Richmond, VA
If you are feeling endevorous, the JEmplode code already supports polling updates to the screen grab, it's just not exposed through the UI. If you wanted to play around with that, it would be pretty easy to turn on polling mode.
Mike
